All Activity
- Today
Snackios Chips joined the community
Problem PLC V1040/V1210
Ruby replied to Ruby's topic in Vision & Samba PLC + HMI Controllers & VisiLogic Software
Gracias!. -
Thanks Saragani. All worked
kellyjohn joined the community
Hello; I am new to the forum and I have the following question; I have to implement a Unistream USC-B5-TR22 on a CAN Bus and I can see that this PLC has a sniffer function, I have tried to obtain information regarding how to use it and implement it in a project but I have not found it or I have been searching wrong, I Can you help by telling me where to find information such as videos, tutorials, etc. I would be grateful. Greetings Guille71
- Yesterday
Does anyone know of any companies that do repair and mobile SERVICE in Michigan for Unitronics?
Aaron Teitlebaum started following Discriminating HiHi, Hi, Lo, LoLo alarms
For the custom alarm type, you can specify HiHi, Hi, Lo, and LoLo limits that will trigger the alarm. Is there any way to tell which of the four limits has been exceeded when the alarm is triggered, other than manually comparing the PV value to each of the limits? The documentation says: This seems to imply that these are four separate alarms (Hi, HiHi, Lo, and LoLo), but as far as I can tell, exceeding any of the limits will all generate the same one alarm. If that's the case, what's the point of being able to specify a HiHi or LoLo alarm limit when this alarm will already have been triggered when the Hi or Lo limit is exceeded?
This looks to me like a single device and you choose which scale reading via MODBUS command. I see no reason to close the connection, once established, nor any reason to use two sockets. I'm not familiar with these scales so I may be misinterpreting something. You can choose the timing between commands without closing the socket.
Flex727 started following Problem PLC V1040/V1210
Flex727 replied to Ruby's topic in Vision & Samba PLC + HMI Controllers & VisiLogic Software
It's telling you what the problem is: "Stop reason ; No Application" This means exactly what it says, there is no application in the PLC. This can be caused by several things, but most likely due to removing power from the PLC with no battery or a dead battery. The solution is to replace the battery and reload the application from VisiLogic. -
Ruby started following Problem PLC V1040/V1210
Ruby joined the community
Shapitheasd joined the community
melanie joined the community
- Last week
Contact Official Unitronics Support at support@unitronics.com. Since the Great Hack of 2023 all previous versions of UniLogic that did not have mandatory security measures have been removed from the Unitronics website and are only available by special request. They should be able to get you the interim versions you need. Joe T.
Joel Page started following How to add an IO-Link DI Splitter
Flex727 started following 1 scale reading bleeds over into the next.
cgerlach joined the community
UniLogic fails to connect USP-104-B10
jeepers52002 replied to JDGleason's topic in UniLogic Software
I realize this is somewhat of an old topic but I'm just pulling one of our UniStream PLCs off the shelf for the first use in a long time. I tried updating the firmware in two steps, from 1.28.39 to 1.31.122 and then to 1.36.44. At no time have I been able to connect to the PLC from ethernet, directly connected to my PC. If I monitor the traffic through the windows connection properties, data is being sent/received constantly but UniLogic will not find the PLC. My UniLogic version is 1.36.63, downloaded and installed today. Any assistance would be greatly appreciated. Thanks! -
I was excited to see the new version of Unilogic supports IO-Link. This has made it much easier to support the devices I'm adding but I have one problem. The manual specifies that splitters are supported and even has a picture of a config where they are added with the icons: However, I only see the option to add a Single Digital I/O I've searched the manual and site but can't find any other references to adding splitters. I can add my other devices fine.
There's a big difference between sending MODBUS commands to a device that doesn't care what you send it and sending it to a MODBUS device. For testing purposes I'd do as Joe recommended and get the software setup correctly with no errors and then fault it out and see what you get for responses and such. The different errors are going to cause a different timeout. A CRC error for instance is a lot different than a "I can't find the device anywhere" error. One is a pure communication error and the other isn't.
I've tried the same setup all the way down to 9600 baud. Performs the same - no comms errors, but same Modbus issues. My issues come down to not being able to transmit after a timeout (error -11). I know that when I get a Modbus operation error = -2, that means the slave messaging suspension is being enforced so you have to wait 3+ seconds before attempting another Master transmission. The issue is when I get a timeout error (-11) - how long a delay (if any) are you supposed to have before you try another Master transmission? Unitronics claims this 3 second suspension only happens after a -2 error, but in my testing, if I get a timeout error (-11) and try to transmit another command with the 3 seconds, it THEN causes the -2 error. This seems to indicate that ANY error causes the 3 second suspension and the -2 just reports to you that you are still within this suspension state if you try another transmission. This is of course contrary to what Unitronics support is telling me, but its the only thing that makes sense.
All, I have one multiscale indicator that has 2 scales that i am trying to read through one Modbus connection by switching the command number to witch scale i need. the problem is i connect, write, and read the command for scale one, then i close the connection to the socket and let it cool for .4 seconds ive even tried up to 1 sec. then i connect and do the same for scale 2. they both are reading and writing to separate vectors and addresses but i get a bleed over reading from scale one onto the scale two and vice versa. i do not know how to resolve the issue. ive set is to where the read and write command are disconnected when the opposite scale is writing and reading. I've put program below, any advice would be appreciated. scale switching.vlp
