gongue Posted December 7, 2011 Report Share Posted December 7, 2011 my proyect has 4 V570 and one pc with InduSoft hmi, but when i start it, the error 111 by uniopc overflow. I could say what the significance of this error to correct it? advance thanks. Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 8, 2011 Report Share Posted December 8, 2011 Hi, Which communication type are you using? (RS232,RS485, Ethernet etc..) Which UniOPC version are you using? Make sure you are using the latest UniOPC sever 2.0 Try to increase the time out in channel settings. Anyway if you still face the same problem then check the option to use MODBUS instead of OPC. This way you do not need to use UniOPC server. You just need to set all PLCs to be MODBUS slaves and change in InduSoft to use MODBUS. Quote Link to comment Share on other sites More sharing options...
