What for UniDownloader.exe demands NET FRAMEWORK 4 XP SP3.
alecsvg
Hi!
It is necessary to programming JAZZ. I want to use UniDownloader.exe. But I can't do it. At me the weak computer which badly works with XP SP3. At me it is not established SP2 and SP3. But UniDownloader demands NET FRAMEWORK 4. NET FRAMEWORK 4 demands XP SP3. I search for the small program which will program JAZZ. It is possible simply source codes on With, Basic.
You need to program Jazz via U90Ladder. You need ot find PC, which answers the requirements of thhis software tool. No "shortways" and "workarounds".
When you write the application, you can prepare special Download file from U90Ladder (Tools > UniDownloader designer). Then, this file can be downloaded to the controller via UniDownloader Runner. This application can be downloaded from our site www.unitronics.com and it's relativelly ligth. Anyway, I'll not recommend to use it with a very weak PC.
