raceandski Posted January 4, 2012 Report Share Posted January 4, 2012 I'm having an issue with attachments to emails. I have email in general working properly. PLC V350/TR6 OS 3.4.17 VisiLogic 9.3.1 Build 0 Email via Ethernet. Trying to send email with attachment test.csv from the SD card. In folder excel\excel2. Test.csv contains 1,2,3,4,5 I'm using the example file \Unitronics\Unitronics VisiLogic_C\Examples\Version 900\Project examples\Communications\Email\V570_Send_Email_via_Ethernet.vlp modified for the 350, and with my email server settings. This is what I'm getting --KkK170891tpbkKk__FV_KKKkkkjjwqContent-Type: text/plain; charset=US-ASCII Hello from Unitronics !!! --KkK170891tpbkKk__FV_KKKkkkjjwq Content-Type: application/octet-stream Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename= "test.csv" MSwyLDMsNCw1DQo= --KkK170891tpbkKk__FV_KKKkkkjjwq-- Does the email attachment send as an actual attachment, or is it appended to the body? The MSwyLDMsNCw1DQo= is the part that varies with the contents of the attachment. There is no attachment present in the received email. I've tried a few different files for attachment. Any ideas?Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Ofir Posted January 8, 2012 Report Share Posted January 8, 2012 Hi, Upgrade the OS to the latest and test again. The latest OS is 3.4(25). You can update the OS from the Web from Visilogic help menu -->Check for updates --> Operating system Quote Link to comment Share on other sites More sharing options...
