External Moderators Nacho Posted November 4, 2010 External Moderators Report Share Posted November 4, 2010 No expand to the right but you can come back: ---||--||--||--||--||--||- | -||--||--||--||--||--||- | -||--||--||--||--||--||-() Quote Link to comment Share on other sites More sharing options...
Phil Salkie Posted November 4, 2010 Report Share Posted November 4, 2010 If you're just trying to decide if any of your 100 thermocouples has failed, consider either using a loop, or searching the table of MB bits for a "1" value using the "VECTOR FIND" function block - you'll either get a "-1" result showing that all thermocouples are OK (no "1" values found) or the index value of the first failed thermocouple. Much, much better than making a huge string of normally open contacts. Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted November 4, 2010 External Moderators Report Share Posted November 4, 2010 If you're just trying to decide if any of your 100 thermocouples has failed, consider either using a loop, or searching the table of MB bits for a "1" value using the "VECTOR FIND" function block - you'll either get a "-1" result showing that all thermocouples are OK (no "1" values found) or the index value of the first failed thermocouple. Much, much better than making a huge string of normally open contacts. Hello Phil, I like use advanced functions to reduce the application but sometimes customers like see only contacts and coils. They used to be electrician and understand better the basic ladder logic. I remember when I had to explain one demo in a single net instead the 20-40 nets customer did it... Quote Link to comment Share on other sites More sharing options...
