Raymond Santiago Posted February 27, 2012 Report Share Posted February 27, 2012 I am trying to run UniOPC in Windows 7. My boss gave me a cpu with OS of Win7. Whenever I tried to register the PLC connection, an error of Run-time error '-2147352567 (80020009)': Exception occured. Is there a way to use the application with my current version? Any help is greatly appreciated! System specs: OS: Windows 7 Professional (32bit) processor: i3-2100 CPU speed: 3.10 Ghz Memory: 4GB Best Regards. Quote Link to comment Share on other sites More sharing options...
Raymond Santiago Posted March 2, 2012 Author Report Share Posted March 2, 2012 I am trying to run UniOPC in Windows 7. My boss gave me a cpu with OS of Win7. Whenever I tried to register the PLC connection, an error of Run-time error '-2147352567 (80020009)': Exception occured. Is there a way to use the application with my current version? Any help is greatly appreciated! System specs: OS: Windows 7 Professional (32bit) processor: i3-2100 CPU speed: 3.10 Ghz Memory: 4GB Best Regards. This topics is already solve! I already solved this problem, Thank you guys! Quote Link to comment Share on other sites More sharing options...
juan.lopez@avanzate.es Posted January 19, 2015 Report Share Posted January 19, 2015 I had the same problem. What is the solution ?? Quote Link to comment Share on other sites More sharing options...
Raymond Santiago Posted January 26, 2015 Author Report Share Posted January 26, 2015 Sorry for late response. Have you tried running it as administrator? Installing the program with compatibility to Windows XP? Quote Link to comment Share on other sites More sharing options...
sakthiautomation Posted February 27, 2015 Report Share Posted February 27, 2015 We are using unitronics V350 series PLC and trying to interface with Wounderware intouch 2014 version SCADA, but SCADA supports only window 7 and 8 but UniOPC supports window XP , to solve this issue we are requesting unOPC to upgrade for window 7 and 8 info@sakthiautomation.in from india and mobile no +91 9943909008 Quote Link to comment Share on other sites More sharing options...
