ditchdigger Posted September 28, 2010 Report Share Posted September 28, 2010 Is it possible to rotate a variable on the HMI? For example: if I make several images together into a group, lets say a motor and conveyor assembly, and I want to rotate the assembly. I have not found it possible to rotate on the programming screen although the help tutorial shows a function to rotate an image. I can't highlight the group either and take it to paint to rotate the group. Please advise. This is on a 570-T20 Quote Link to comment Share on other sites More sharing options...
Emil Posted September 28, 2010 Report Share Posted September 28, 2010 The funciton "Rotate" is supported only by classical Vision models - V120/230/260/280/290/530. You can find it when you right click on a HMI object. Enhanced Vision models doesn't support "Rotaste" option. We will improve the Help topic, additng this information. Quote Link to comment Share on other sites More sharing options...
ditchdigger Posted September 28, 2010 Author Report Share Posted September 28, 2010 The funciton "Rotate" is supported only by classical Vision models - V120/230/260/280/290/530. You can find it when you right click on a HMI object. Enhanced Vision models doesn't support "Rotaste" option. We will improve the Help topic, additng this information. Thanks for your prompt reply, Emil. It would be a nice option to have, if possible. Matt Quote Link to comment Share on other sites More sharing options...
