Manfred Posted April 19, 2012 Report Share Posted April 19, 2012 Hello All We are trying to use the PCOM - Protokoll via Radio Modems ( Satel 3ASd ). To find the correct route, these Modems have the ability to detect ( independent of the used protokoll ) the Node - Number ( Unit ID ) of the destination PLC. For this, the Offset and Length of the Node in the Frame have to be configured. So, for PCOM - ASCII, Offset 1 and Length 2 must be configured and everything works fine ! For PCOM - Binary, Offset 6 and Length 1 must be configured and here is our problem: Visilogic uses both ( ASCII and Binary ) Protokolltypes so this setting in the Radio Modem does not work and we are unable to make any program changes or debugging via the Radio Links ! One idea was to modify the PCOM - Frame by adding the Unit ID ( to have a fixed position for both types ) before the STX of the real Frame: For Example Unit ID 01: ASCII - Frame: '0','1','/','0','1',......,<CR> Binary - Frame: '0','1','/','_','O','P','L','C',....,'\' The result was, that there was no response from the PLC so it looks like the PLC does not synchronize to the STX and ignore the additional leading charactes ! I hope somebody has an idea how to solve this problem ! Btw., we are talking about more than 300 ( ! ) Stations connected over 4 different Radio Frequencies ! Manfred Quote Link to comment Share on other sites More sharing options...
