Connect V120 to OPC Systems.Net using UniOPC
Terry Luu
Hi,
As I understand you wish to use Unitronics OPC Server for communicating V120 with the SCADA.
You can download UniOPC server from: http://www.unitronics.com/Data/Uploads/software%20utilities/UniOPCSetup_201.exe
Then you can find in OPC help file detailed explanation how to use the UniOPC Server.
Basically you need to configure the communication channel (57600, 8 , N , 1) and add PLC.
Please note that there is no automatic browse to operands - You will need to add the variables/tags manually.
Review help topic "OPC Client: Item Syntax"
Hi,
You can download UniOPC server from: http://www.unitronic...PCSetup_201.exe
Hi
Yes, I intend to using Unitronics OPC server for communicating V120 with the SCADA, I already connected V120 to PC with RS232 cable. and also connected to OPC SERVER but for SCADA I using an other software from OPCSystems.NET. I can't not find a way to configure and how to hook-up signal from PLC to SCADA software through OPC server. So please help me.
  • 1 year later...
