Edwin Posted May 15, 2012 Report Share Posted May 15, 2012 Hello, I'm using the advanced webserver based on a V350. If I put this program in my V350-B1 it works fine and I can see the different pages, but when I change my hardware configuration to a V570-57-T20B with a V200-18-E3XB print and put the software in the V570 my webserver doesn't work anymore. Could somebody tell me what I'm doing wrong? Thanks in advance, Edwin Quote Link to comment Share on other sites More sharing options...
pascal Posted May 19, 2012 Report Share Posted May 19, 2012 normally this should work fine, I tried this the other way around ( first a V570, then V350) without any problems. did you put a SD card into the V570 ? the SD card is not the same of the V350 and V570 Quote Link to comment Share on other sites More sharing options...
