CltOff Posted October 5, 2010 Report Share Posted October 5, 2010 I'm trying to create files for UniDownLoader but I've some problems. Maybe I'm using the wrong procedure... could someone write me the right way? I tryed to use Project Create proj file but it doesn't work off line I tryed to use Tools UniDownLoad Designer but it ask me files that I don't have Thanks CltOff Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 6, 2010 Report Share Posted October 6, 2010 Which PLC model are you using? Quote Link to comment Share on other sites More sharing options...
CltOff Posted October 6, 2010 Author Report Share Posted October 6, 2010 Which PLC model are you using? V120-22-RA22 Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 6, 2010 Report Share Posted October 6, 2010 Ok, so in that case you must have the PLC connected to the computer. New PLC models (V570, V130, V350) doesn't require any PLC to be connected in order to create a UniDownloader file. Quote Link to comment Share on other sites More sharing options...
CltOff Posted October 6, 2010 Author Report Share Posted October 6, 2010 Quote Link to comment Share on other sites More sharing options...
