guttih Posted August 21, 2012 Report Share Posted August 21, 2012 My PLC is V350-35-T2 I have been having trouble displaying in my PLC a trend written to my SD card. I am able to write the trend to the SD Card and view it in the SD Card Manager but I am not able to view it in my PLC. I write the active Trend to a file called InnUt.utr When I try to use the "Trend from SD" variable in another display, it displays nothing. When the file "InnUt.utr" does: -exists the "Trend load error bit" is "0" -NOT exists the "Trend load error bit" is "1" So I must have the filename and folder correct in my program. Can anyone help me figure out how to display the the Trend in my PLC? Quote Link to comment Share on other sites More sharing options...
guttih Posted August 21, 2012 Author Report Share Posted August 21, 2012 I see what the problem is.... I was remotely programming and running the PLC. When I viewed the SD Trend on my computer (via the "Online Test" and the "Remote Operator), SD display screen showed only a blank screen . But when I went to the site and looked at the screen on the PLC it self I saw the values and lines of the SD Trend. So my conclusion: There must be some kind of bug in the "Online Test" and the "Remote Operator" when viewing the SD Trend. Quote Link to comment Share on other sites More sharing options...
Emil Posted August 21, 2012 Report Share Posted August 21, 2012 Sorry for the problem you faced. This is not a bug. Just Remote Operator doesn't support yet Hystorical tgrends. This is in our future plans. Quote Link to comment Share on other sites More sharing options...
guttih Posted August 21, 2012 Author Report Share Posted August 21, 2012 I understand, Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
