sgull Posted August 28, 2012 Report Share Posted August 28, 2012 Hi All I am quoting a project and plan to use a vision 1040. I need the following I/O count Digital in 100 Digital out 50 Analog in 16 Analog out 8 Can you suggest the most suitable hardware configuration. Regards Denis Morrissey Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 29, 2012 MVP 2023 Report Share Posted August 29, 2012 You're going to need to use some EX-RC1's for this many modules- Separate 24V power supply for the CANbus (3) EX-RC1 (7) IO-DI16 (4) IO-RO16 (2) IO-ATC8 (2) IO-AO6X I wouldn't confuse the issue by using a snap module. Keep it all on the back panel. Joe T. Quote Link to comment Share on other sites More sharing options...
sgull Posted August 29, 2012 Author Report Share Posted August 29, 2012 Thanks Joe I was thinking of using a snap in but the configuration you suggest will certainly be better if we need to add on again after. Regards Denis Quote Link to comment Share on other sites More sharing options...
