HylkeBakkerGasunie Posted November 8, 2012 Report Share Posted November 8, 2012 I'm starting Remote Operator from a commandline. I'm using the commandline parameter /O= to point to the .ur2 file I want the user to start with. In the UR2 file I saved startup settings for RDP/VNC mode and Autorun. When I use the /O parameter the autorun doesn't work. Are there also parameters to set autorun and rdp/vnc mode through the commandline ? Or is it possible to enter this information in the remote operator.exe.config? I tried that, but in that case I saw that for a new user the program is looking for the ur2 file at the directory mydocuments from the user. The file can be found in the projects directory from the Remote Oprator program directory and not in the my doduments directory. I would like to prevent that the user must browse through the system to fund the ur2 file. Regards, Hylke Bakker Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 8, 2012 Report Share Posted November 8, 2012 The RDP/VNC mode and Autotun is not inside the ur2, but in a config file saved in program data folder. I'll loot at the code on sunday and give you a more detailed answer Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 11, 2012 Report Share Posted November 11, 2012 Hi, I have checked and autorun from command line is not supported. However, I have added a support for it, and you will have it in version 1.0.36 Usage: /o="C:\Some Folder\Another one\My test.ur2" /autorun=true Quote Link to comment Share on other sites More sharing options...
HylkeBakkerGasunie Posted November 13, 2012 Author Report Share Posted November 13, 2012 Hi, thanks for the addition. Is there a manual, where the use of the remoteoperator.exe.config items are described? Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 13, 2012 Report Share Posted November 13, 2012 No, because the RemoteOperator.exe.config doesn't have much of a config There is the EnableLogger which is for communication debugging (Requires the ComDriver log viewer in order to open the logs). The other options doesn't do anything... (because the actual settings are saved under the User profile) Quote Link to comment Share on other sites More sharing options...
