RickM Posted October 21, 2010 Report Share Posted October 21, 2010 I recently was having a problem with the CSV delimited write function and it was suggested on the forum that I make sure I was using Visilogic 8.6.1 and O/S 3.1(19). Since I have updated to O/S 3.1(19) and Visilogic 8.6.1 the send email with attachment has stopped functioning. It is working in the field in the code created in version 8.6.0 and on O/S 3.1(19) and O/S 3.1(5). I connect to the email server (SB 150), but I do not get send email in progress SB 345. I have since upgraded to Visilogic 8.6.2 (deleted the email function and rebuilt it) and the same problem is occurring. Rick M Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted October 24, 2010 Report Share Posted October 24, 2010 In order to solve the problem try the following: 1. Perform a Built All procedure (Build >> Build All). 2. Use a different mail server. If this doesn't work let me know the following: Are you able to send an email without attachment? Does the status messages of the email change when you send it? and send me the application in question. Quote Link to comment Share on other sites More sharing options...
RickM Posted October 28, 2010 Author Report Share Posted October 28, 2010 Stein None of the above resolved the problem. I snt both applications to your attention to tech Support on October 15th. Rick M Quote Link to comment Share on other sites More sharing options...
