rohitigupta Posted November 22, 2012 Report Share Posted November 22, 2012 Hello, I have developed an application to communicate with PLC installed on plant and accessing it from Server through Ethernet. we have developed & tested the application on Windows 7 OS(32 bit), and installed on Windows 2003 R2 server (64 bit), but after running the application we got following error : Could not load file or assembly 'Unitronics.DataTables, Version=1.0.0.13, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format. we also tested this application to run on Windows XP os and its working nice, but we need to run this on our server, Kindly please help me to solve this issue. Regards.. Rohit Gupta rohit@idstechnologies.co.in +918879225951 Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22, 2012 Report Share Posted November 22, 2012 Since the .Net driver and the Communication Driver are compiled for x86 (it is required for the logger of the communication driver, since it uses Access which is only supported in x86), you need to also compile your program as x86. Quote Link to comment Share on other sites More sharing options...
rohitigupta Posted November 22, 2012 Author Report Share Posted November 22, 2012 Thanks Alex, I will update my program as required. Regards... Rohit Gupta Quote Link to comment Share on other sites More sharing options...
