MVP 2023 Flex727 Posted November 28, 2012 MVP 2023 Report Share Posted November 28, 2012 I wonder if someone from Unitronics, or some other knowledgeable person could provide a detailed explanation of how Timer Presets behave. With Timers, there is an extra option besides just "Power Up" value being set or not set. I can enter a Timer Preset in Visilogic without checking the box for the "Power Up" value and that Preset gets transmitted to the PLC during program load. If I subsequently change that Preset, either in Visilogic or in the PLC, then there will be a dialog box requiring me to harmonize them if I do another program download. However, if I load the same program via the SD card I get different behavior. It appears to me that the Timer Preset in the program on the SD card (either .v57 or .c57 file) is ignored when downloaded. I would think, especially when I'm downloading a Clone program, that the resulting PLC would be identical to the PLC that uploaded the file. This is not the case with respect to Timer Presets. What is the behavior I should expect? And is it any different if I have checked the "Power Up" box in the programming? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 2, 2012 Author MVP 2023 Report Share Posted December 2, 2012 Here is what my testing reveals: 1) It makes no difference whatsoever if the "Power Up" box is checked for Timer Presets. If the Timer Preset is changed from its original value a Reset does not change the Preset and an Initialize returns the Preset to the original value whether the box is checked or not. 2) If the application is downloaded to the SD card, a subsequent upload to the PLC has no effect on Timer Presets no matter whether the Presets were changed or not. Whatever value was in the PLC at the time of the upload remains in the PLC. In other words, if the Timer Presets were messed up, whether inadvertently or otherwise, THEY CANNOT BE FIXED BY AN APPLICATION UPLOAD OR EVEN A CLONE UPLOAD! This caused me some embarrassment at a customer site last week. I expected a Clone to mean a Clone, not Clone everything EXCEPT Timer Presets. 3) If the Operands are downloaded to the SD card, then an Operand Upload WILL CHANGE THE TIMER PRESETS. Is this information helpful to anyone? Is this the behavior I should have expected? Quote Link to comment Share on other sites More sharing options...
Damian Posted December 2, 2012 Report Share Posted December 2, 2012 Flex, It is definitely helpful. I myself am not a fan of how visilogic handles retentative values and especially that of timers. I would much rather see the "initial values" method completely abandoned in favor of the "current values". When I want to make abosolute certain I am cloning the operand values I use the "Remote Access" utility and uload all those values into a csv file. I also do not reference timers directly but instead buffer all presets using MI operands. This circumvents some of the flakey behavior you note above. 1 Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted December 3, 2012 Report Share Posted December 3, 2012 Thanks for info, it´s ver useful. I´ve always expected to be able to set default (My default) timer preset values such as any other operands, using power-up initialize option. Those timers which user must not modify, I preset using ML and store timer preset function in ladder. Clone should be complete. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 4, 2012 Report Share Posted December 4, 2012 Hi Flex727, Please - if you want to get answer from "someone in Unitronics", the best way is to send the question to "someone in Unitronics" - to support@unitgronics.com. We are making our best to give high level professional answers within 24 hours. A post in Forum is oriented to large sociaty of users and we give especially chance to other users to participate and give their opinion. If thhere is a need - post with answer we don't hully agree with or no answer for several days, we participate. About Timers: Power Up check box with timers is to state, that on power up the curent value of the timer will be reset. The Preset value in the Timer box is loaded with Download to Flash memory of the controller. When one change the timer preset value, the new valye is stored in RAM. While Download again, VisiLogic checks if there is difference between values in RAM and in FLASH and asks how to synchronize. As I know, this option will be optimized in the new VisiLogic version to give the programmer option to select synchronizing way for each timer, where there is a difference. About clonning - please let me check your claim and I'll post the results later. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 4, 2012 Author MVP 2023 Report Share Posted December 4, 2012 Thank you. I posted here with the assumption that the information would be of general interest. I definitely appreciate your customer support and it's certainly a major reason that I prefer to use and recommend Unitronics whenever I can. Regarding the Timer Power Up check box, you say: "Power Up check box with timers is to state, that on power up the curent value of the timer will be reset", BUT THAT IS NOT WHAT HAPPENS! Whether the box is checked or not, the Timer Preset does not revert to the Power Up value on power cycle or manual RESET. When uploading a program from a laptop vlp file, the Visilogic software will always require the timer presets to be synchronized and will not proceed without changing the preset values in either the laptop or the PLC. However, when uploading a program from an SD card, the upload completely ignores the timer preset, whether from an application (v57 file) or from a clone (c57 file), AND WILL NOT CHANGE THE VALUE IN THE PLC. I consider both of these situations to be flaws. By the way, if it's important, I am using Windows 7 - 64bit, Visilogic 9.4.0, and a Vision 570 OPLC. Quote Link to comment Share on other sites More sharing options...
Bisi Posted February 26, 2016 Report Share Posted February 26, 2016 Someone please help, How can I find out where the timer function is located on Visilogic ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 26, 2016 Author MVP 2023 Report Share Posted February 26, 2016 Timer functions in Ladder are simply Contacts and Coils with Timer selected instead of Bits. Once you've selected the Timer address you want, you can then select which of the 3 Timer types you need. On the HMI, click the Timer icon on the sidebar. Quote Link to comment Share on other sites More sharing options...
