jth Posted December 7, 2012 Report Share Posted December 7, 2012 Hello. I am programing Unitronics V1210 with VisiLogic v.9.4.0. The program I am working at, does suddenly not work as it should, when I touch the numeric displays with Keypad Entry, there I am supposed to change the numeric values, nothing happens, No keypad pop up. And if I goes to the Information mode the password is requested, the password windows pops up but then nothing hapens, I cant type the password and cant escape. I have puted in older version of my program that did work before, but now the same problem is there, the keypad window wil not appear, but It comes a little flash on the screen. Is there a solution for this problem? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted December 7, 2012 MVP 2023 Report Share Posted December 7, 2012 Can you upload your program for us to examine? Joe T. Quote Link to comment Share on other sites More sharing options...
Damian Posted December 7, 2012 Report Share Posted December 7, 2012 This is happened to me before on a V1040 and I ended up having to re-install the OS. A colleague of mine also had a similar problem as this and he ended up having to pull the Ethernet adapter out. Don't know if you are using ethernet but it might be worth a try. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 9, 2012 Report Share Posted December 9, 2012 Without seeing your application...just a shot in the dark... I had a similar problem with a V570. Turns out I had an active "Show Alarm" function block, but there there was no alarm configured for the ID# specified, so it didn't appear on the screen. I could navigate through various screens no problem, but any fields/buttons that required pop-up keypads were not functional. Dave Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 9, 2012 Report Share Posted December 9, 2012 Hi, It seems the applicaiton calls a display evey scan. Check that all the conditions for calling a display are with one shot condition. As Dave mentioned also calling the alarm display (using Show alarm /shpw groups) should be activated with one shot condition. Quote Link to comment Share on other sites More sharing options...
