Tomasz Posted October 25, 2010 Report Share Posted October 25, 2010 Hi, I have problem with "Illegal Word Operand Access" situation. I have: PLC: V570-57-20B / Firmware: 003.001.19 Jul 15 2010 VisiLogic: 8.6.1 Any time I have reset alarms (using Unitronics build in function about alarms), system go to this illegal Word Operand Access and put PLC on stop mode. All this start when I update from firmware 15 to 19. I return to firmware version 15 and there is no problem. Is firmware version 19 unstable yet? Any suggestions? Best regards Tomasz Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted October 28, 2010 Report Share Posted October 28, 2010 Try updating to OS version 3.001 (27). It is available in version 8.6.3 of Visilogic which can be downloaded from Unitronics' website under Support >> Downloads. Quote Link to comment Share on other sites More sharing options...
Tomasz Posted October 28, 2010 Author Report Share Posted October 28, 2010 Thanks for answer, It solve this problem and so far so good. I will be testing this version (27) more. best regards Tomasz Quote Link to comment Share on other sites More sharing options...
Tomasz Posted November 2, 2010 Author Report Share Posted November 2, 2010 Hi, After Testing version (27), I found it was only partially corrected. If I use reset button alarm on first screen (groups with pending alarms) it still make "Illegal Word Operand Access" using reset button on "alarms in group" or "alarm details" works fine. I guess Unitronics will own me 20$ for debugging for them :-) I am looking forward for some updated version of firmware before release to client. (I suggest to do the same for others users of V570) best regards Tomasz Quote Link to comment Share on other sites More sharing options...
Arjun Posted January 12, 2011 Report Share Posted January 12, 2011 Actually i m also getting the same error as Illegal Operand Accessed and I found that whenever I change some of the data table data and save it, then the Illegal Operand Accessed error is generated and PLC go to stop mode in case of resetting the alarm from the group as well as in detail view. Quote Link to comment Share on other sites More sharing options...
Ofir Posted January 12, 2011 Report Share Posted January 12, 2011 Hi, I tried to simulated the error using V570 with OS 3.1(31) without success. Attached is the application i tested with. I tried to reser alarms from Groups view or details view but no error occured. Try updating the OS to the latest and test again. V570 Alarms.vlp Quote Link to comment Share on other sites More sharing options...
