markofdiego Posted December 20, 2012 Report Share Posted December 20, 2012 I am trying to create some icons that behave the same as the built in ones that are in the imagesC directory. The images that I make do not seem to be able to have a transparent background. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 20, 2012 MVP 2023 Report Share Posted December 20, 2012 Fill the area you want to be transparent with a color not used in the icon or image. Make sure there is a pixel of that color in the upper left corner. When you assign the "Transparent" property to the image, Visilogic will make every pixel of that color transparent. Quote Link to comment Share on other sites More sharing options...
Damian Posted December 21, 2012 Report Share Posted December 21, 2012 What image format are you using? Quote Link to comment Share on other sites More sharing options...
