Gal.I Posted January 8, 2013 Report Share Posted January 8, 2013 I'm using the drum FB in VisiLogic 9.4.0 I would like to print the configuration I've created - what should I do ? For the the drum configuration window, it would help if the window size could be changed Quote Link to comment Share on other sites More sharing options...
Ryan Posted January 8, 2013 Report Share Posted January 8, 2013 Your best bet would probably be to take a screen shot of the config window, you can print your entire ladder from Visilogic but there is no option to print individual function blocks. If you don't already have a screen capture tool installed on your PC I would highly recommend using www.snagit.com Quote Link to comment Share on other sites More sharing options...
Gal.I Posted January 9, 2013 Author Report Share Posted January 9, 2013 Thanks for the reply. I'm using this method now but since I have a large drum configuration I need to "patch" the complete configuration from several screen shots I would expect at least for a way to expert the table to a file Quote Link to comment Share on other sites More sharing options...
