Vidmas30 Posted January 16, 2013 Report Share Posted January 16, 2013 Good day, We have deaerator control system where used V570 with ETHERNET card (PLC always conected with Unitronics remote access software). As we started application, all was well, but after couple of month, now we have fatal error screen several times a week. The information on screen told me local supervisor: V290/B570(T20B) O.S. (STOP MODE-FATAL ERROR) 003.004.25 November 27, 2011 9:56 ---------------------------------------------- ENUM: 0x0001100 00000000 IP: 0x0007043A 0007766A LDR: 0x0000017A DESC: ILLEGAL WORD OPERATED ACCESS STATUS: IDLE © COPYRIGHT BY UNITRONICS Maybe someone coul tell what may be the cause of that fatal error? We assigned IP address to Ethernet card that was free at the moment we were installing PLC. Could this fatal error be if they for example bought new computer and used same IP address as PLC's? Thank you very much and looking forward to solve this issue asap.. Quote Link to comment Share on other sites More sharing options...
Ryan Posted January 16, 2013 Report Share Posted January 16, 2013 Fatal Error is usually caused by an error in the program, divide by zero, stuck in a loop, trying to call a variable that doesn't exist, etc. If you send your program to support@unitronics.com with a description of the problem we should be able to help you find a solution. Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Thank for quick anwer, As I mentioned: program went good couple of months. Then something happened with ethernet connection (ethernet card was stopped, SDW39 showed error status in info mode). After RESET, all was good. But then begun fata errors. I still think that it's something with communications.. Is there possibility to tell the exact reason by these error messages I wrote? Quote Link to comment Share on other sites More sharing options...
Emil Posted January 16, 2013 Report Share Posted January 16, 2013 The reason for Fatal error can be also strong picks of electromagnetic noise. Maybe something changed in the controller environment? New big machine? Or contactor in the cabinet started to perfomr worst, emmiting more noise? You can try function "Check subroutine by error code" (VisiLogic > Edit menu). This function will point you to the subroutine, where the application stopped with this fatal error. This can give you some direction. 1 Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Thank you, Emil, Very helpful - as always I will go there next week and will try your suggestion! Quote Link to comment Share on other sites More sharing options...
