krasoff Posted October 28, 2010 Report Share Posted October 28, 2010 Hi to all! Problem: I have APC PowerChute Network Shutdown which turns off PC when dissappears power. On this PC installed UniOPC 1.3.8 which works with OPCLink 8.0. When APC PCNS send a command "Shutdown" to PC, PC does not turn off. When I stopped UniOPC, PC shutdown normally. Question: Why working UniOPCServer disturbs shutdown system? P.S. Where a changelog the latest versions of UniOPC? Thnx! Quote Link to comment Share on other sites More sharing options...
Emil Posted November 7, 2010 Report Share Posted November 7, 2010 Is this happens only with UniOPC server? Did you try with other OPC server? Quote Link to comment Share on other sites More sharing options...
External Moderators Ash Neilson Posted November 7, 2010 External Moderators Report Share Posted November 7, 2010 Emil - Thought I would post something on this too. I find with all versions of UniOPC Server that you need to click the "STOP" Button before UniOPC can be Closed. If I remember correctly, the reason for it was to prevent people from exiting UniOPC while it was running. Quote Link to comment Share on other sites More sharing options...
LenkoTerje Posted May 21, 2012 Report Share Posted May 21, 2012 Was there ever a suggested solution or workaround for this behaviour? Quote Link to comment Share on other sites More sharing options...
Ruark Posted October 12, 2012 Report Share Posted October 12, 2012 Hi everyone! I've got the same problem. We need to do something with UniOPC to make it "auto stop", in order to shutdown computer automaticly in the case of power loss. Guys, maybe you should add such a choice to the UniOpc options, like "auto shutdown", to stop and exit UniOpc when connected SCADA stops and closes ? By the way, I've explained this problem to Emil, when he was visiting Unitronics conference in Kiev, Ukraine this year, maybe they are already doing something ? Quote Link to comment Share on other sites More sharing options...
