VB .Net error
A_Mia
All,
I need to write to a timer preset and am getting an 'object' error using the .net driver.
I'm sort of between a rock and a hard place...
THanks in advance.
Below is the 'function' that attempts to write -
Public Function Write_TimerPreset(ByVal tmrIndex As Int16, ByVal TmrValue As integer) As Boolean
Dim values As Object() = New Object(2) {}
Try
values(0) = DirectCast(TmrValue, Object)
Catch
System.Windows.Forms.
MessageBox.Show("One of more of the values are not valid")
Return False
Exit Function
End Try
Dim wo As WriteOperands = New WriteOperands()
With wo
.NumberOfOperands = 1
.OperandType =
OperandTypes.TimerPreset
.StartAddress = tmrIndex
.Values = values
.TimerValueFormat = TimerValueFormat.SecondsFormat
End With
Dim rw(0) As ReadWriteRequest
rw(0) = wo
Try
plc.ReadWrite(rw)
Catch
Dim ErrorMessage As String = "Could not communicate with the PLC" & vbCrLf & "Error # " & Str(Err.Number) & " was generated by " _
& Err.Source & vbCrLf & Err.Description
'Display the message as a critical message.
MsgBox(ErrorMessage,
MsgBoxStyle.Critical, "PLC Connection Error")
CaptureErr(EquipmentPK,
"Unitronics Class", "Write_TimerPreset", Str(Err.Number), Err.Source, Err.Description, Now(), EmployeePK, 0)
Return False
End Try
Return True
End Function
That's because you have a 3 values array and only the first one has a value (while the other 2 are Null, ergo Null Reference exception), and you are also writing only 1 value so no need to 3 values array.
instead of:
have it:
Dim values As Object() = New Object(0) {}
