Sign in to follow this
Ladderlogics
Project downloading via GSM to Vision 570
Hi,
Is there any way of downloading applications to Vision 570 and 350 controllers via GSM modem? I have used the Project Downloader successfully with M90 and JAZZ controllers, but to my dissapointment this feathure is disabled with previously mentioned PLC:s
Hi, once you have established a connection with the PLC via a modem, downloading applications to the PLC is performed the regular way. you just need to make sure that the activated COM port is set to the one which the modem is connected to.
This is done in the Connection menu under Communication & OS in the PC Port field.
 Great!
Having tried it now, it seems more than obvious that it works like this. In other words too easy ;)
BR.
Ari
