Save Project File security permissions
In Windows 7 using VisiLogic 9.4.0 when I save a project, the file security permissions are set so that only I (or administrator) can see the file. It does not set the "Everyone" permission. I have to go set it manually each time so the file can be shared across our network. Is there any way I can change it so the "Everyone" permission is automatically included?
All Unitronics software is intended to be run with administrative privlages. It also requires the User Account Control (UAC) to be turned all of the way down. Please ensure your users attempting to access these files have the same privlages and or settings to ensure they can open the files as intended,
