Cara Bereck Levy Posted April 29, 2013 Report Share Posted April 29, 2013 This replaces the Help file that was released with VisiLogic 9.5.0. Download the .rar file attached to this post. Unzip the file VisiLogic.gif Rename it to VisiLogic.chm. Copy it into the VisiLogic Directory, typically: \Program Files\Unitronics\Unitronics VisiLogic_C\Help (overwrite the existing VisiLogic.chm. Note that this new Help file fixes several reported issues, including a missing Timers topic. VisiLogic.rar 1 Quote Link to comment Share on other sites More sharing options...
Tony Spearing Posted April 29, 2013 Report Share Posted April 29, 2013 Thanks for that Cara I also found that after I had extract the Visilogic.gif but before I copied it to the program directories I had to right click the file, go to Security, and 'Unblock' it. I also opened it as well then it made me a Visilogic.chw file and I copied that over as well. Hope this helps. Tony Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted April 29, 2013 Author Report Share Posted April 29, 2013 Ah--thanks Tony for the input. I will check into this issue--what Windows are you running? 7? Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted May 7, 2013 MVP 2014 Report Share Posted May 7, 2013 Mine updated OK. Is there a plan to allow this to be updated via the Visilogic menu - Help -> Check for Updates -> Help ? Quote Link to comment Share on other sites More sharing options...
lawry Posted May 7, 2013 Report Share Posted May 7, 2013 Hi, Have just updated to this Help file. Need clarification. SB 162 in the operands list in Visilogic stands as "Link failed after card was properly initialized", whereas the new help file states SB 162 to be "Ethernet Reconnect parameters saved". Has the operation of this bit changed? Lawry Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 7, 2013 Author Report Share Posted May 7, 2013 Hi Lawry, There hasn't been a change, but I will check into the discrepancy between the SB operand description and the Help--thanks for drawing my attention to the issue Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 7, 2013 Author Report Share Posted May 7, 2013 OK--SB 162 fills the function described in VisiLogic: "Link failed after card was properly initialized". To automatically renew the link, use SB 168 to activate "Link lost, auto-recover": Set SB 168 to Power-up Value =1. I have already fixed the Help file, and it will be in the next version. Thanks! Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 7, 2013 Author Report Share Posted May 7, 2013 Simon, it will be--but not quite yet. I have actually been fixing some other minor issues in the file. I hope to issue another version in a couple of weeks, and hopefully this will be included in the utility Update from the Web. Quote Link to comment Share on other sites More sharing options...
lawry Posted May 7, 2013 Report Share Posted May 7, 2013 Thanks Cara, Your new profile looks good. Lawry Quote Link to comment Share on other sites More sharing options...
gongue Posted May 21, 2013 Report Share Posted May 21, 2013 pardon my folder has no visilogic.chm has visilogic.chw. although I did what I suggest, was not overwritten anything, as I have the best version of help? Quote Link to comment Share on other sites More sharing options...
jbs_jakub Posted January 14, 2014 Report Share Posted January 14, 2014 Thank you Cara, it solved my problem with missing help chapters Ladder->Calls: Program Control. Is there any way to recive emails about important fixes and updates for registered users? Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 16, 2014 Author Report Share Posted January 16, 2014 We generally post important stuff in the forum :-) Quote Link to comment Share on other sites More sharing options...
