Guest Jan N. Posted May 10, 2013 Report Share Posted May 10, 2013 Hello! I have problems with downloading the application to one of our V230. Also It doesn't connect with Remote Operator (RO) program. Strange thing is that VisiLogic can do Online Test and then it shows all the online parameters and also remote access can be used during online test. The problem stands in both way, wether I try to download or connect with RO through ethernet or through RS232 (COM1). I was able to download the aplication short time after restart of PLC, but it ended also with some kind of error. Although the PLC seams to work fine and seams that the modified program was downloaded (despite of occured error), I'm not able to download again. I put the pictures of the error messages also here. Does anyone have a clue what can be wrong? Jan Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 10, 2013 Report Share Posted May 10, 2013 What version of Remote Operator are you using? Quote Link to comment Share on other sites More sharing options...
Guest Jan N. Posted May 10, 2013 Report Share Posted May 10, 2013 Hi! I am using Remote Operator 1.0.30.0. I have two of those V230 PLC-s, one of them with very similar aplication is working perfectly another one doesn't. Jan Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 11, 2013 Report Share Posted May 11, 2013 Hi, I remember a problem with remote operator that it fails showing displays on some of the V2xx PLCs. I think that on version 1.0.36 it is already fixed (so try it and tell me if it helps) Quote Link to comment Share on other sites More sharing options...
Guest Jan N. Posted May 13, 2013 Report Share Posted May 13, 2013 Hello! I renewed my operator program and it didn't help and also I haven't sorted out the download issue. Sometimes VL says that the PLC is buisy with processing the download, but the download has been done long ago (many days). May the PLC be broken? What can cause the download problem? Jan Quote Link to comment Share on other sites More sharing options...
