BenB Posted May 16, 2013 Report Share Posted May 16, 2013 Hello, I am trying to set up a V130 to send out text messages. I am using the Enfora modem and have set everything up correctly I believe. I am using COM1 and have changed the internal jumpers to RS232. I have the COM INIT 1 block running on power up with a baud rate of 9600. I have used the Modem Services to 'Prepare PLC-side modem' with a baud rate of 9600 as well. When I plug the modem into the v130 and cycle power the connection fails (ie SB81=1). Can anyone give me insight as to what I am doing wrong? Thank you, BenB Quote Link to comment Share on other sites More sharing options...
Walkerok Posted May 17, 2013 Report Share Posted May 17, 2013 Is your modem making a connection to the cellular network (solid green light on the enfora). If not you will not be able to connect to the modem to the PLC. Keith Quote Link to comment Share on other sites More sharing options...
