Paul Rylatt Posted May 31, 2013 Report Share Posted May 31, 2013 I am using a V130-T4-TR6 and need to verify some information on the HSO output that seems contradictory between the tech spec and the V9.5.0 help file. Per the tech spec, the HSO freq. range is 5Hz to 200kHz. According to the help file, a value of 0 can be used but is not mentioned in the tech spec. It seems that the 0 value is used for a constant "ON" signal. Is this value available in the V130 and if so, please verify its function. Quote Link to comment Share on other sites More sharing options...
Emil Posted June 3, 2013 Report Share Posted June 3, 2013 Hi Paul, The min frequency is 5 Hz. We will take care to update Help topic. Quote Link to comment Share on other sites More sharing options...
