MVP 2023 Flex727 Posted August 9, 2013 MVP 2023 Report Share Posted August 9, 2013 Anyone know what the "Fix" button does when in the Operand Mode section of Information Mode? I cannot find any documentation on this button. Also, If I need to get to, say, Memory Bit 7000, is there an easier way to get there other than pressing the down arrow 175 (!) times? Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 9, 2013 Report Share Posted August 9, 2013 There indeed is an easier way instead of scrolling, you can manually select which memory operand you wish to view. To do this click on one of the addresses on the left then manually enter the value of the operand using the keypad entry. Selecting the fix button loads the display starting at the top address location. For example if you manually enter address 4500 into the top location, then press fix. This will then allow you to use the normal scroll functions starting from that top location.The entire display will jump to the location starting at 4500, with the next address at 4508, 4516, etc. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 10, 2013 Author MVP 2023 Report Share Posted August 10, 2013 Thank you! Quote Link to comment Share on other sites More sharing options...
