Luciak Posted November 19, 2010 Report Share Posted November 19, 2010 Hello. I'll try to as precise as I can because it is quite complicated. I have V130-33-R2. It has one COM port which is configured in ladder to Modbus RTU. Communication is ok - I read PLC via modbus. When I want to update programme in PLC or just have online look on registers - I plug in the cable and VisiLogic do some magig and reconfigures the COM port back to PCOM mode from Modbus. And here everything is ok also. I have such a installation: V130 -> via cable -> GPRS modem -> via GPRS -> SCADA server -> SCADA system And I can read registers via Modbus - everything's OK. The problem starts at this point (I'll just mention that this works with U90 Ladder and Jazz or M-91 PLCs). When I try to update program remotely like this: My PC -> via GPRS -> GPRS modem -> via cable -> V130 It is trying to connect and is failing - I get info as if the cable was not connected. I tried to send to SI 115 value 0 to change it to PCOM mode (from 1 which is Modbus) and it was ok - as I saw in Info mode in communication - it had changed. But it didn't help - still couldn't connect. Any ideas how to do that? Quote Link to comment Share on other sites More sharing options...
Luciak Posted April 26, 2011 Author Report Share Posted April 26, 2011 Solution - if any one wolud have the same concern. What I did was putting another piece of code to set the Com Port into PCOM mode. The code was triggered by MB which I could set via ModBus. So it works like this: PLC is running and is transmitting data with ModBus via GPRS. When I want to connect to PLC with VisiLogic I just send instruction/order through ModBus to reconfigure Com Port info PCOM mode. And I can connect to PLC. After I finish working, I just reconfigure the Com Port to ModBus and disconnect. I have also added a timer (1 hour) which starts after I reconfigure the Com Port to PCOM. When it is done - Com Port is reconfiguring to PCOM automaticlly. It is just in case I forget to reconfigure Com Port to ModBus by myself. Quote Link to comment Share on other sites More sharing options...
