Cara Bereck Levy Posted October 16, 2013 Report Share Posted October 16, 2013 Flex--you are in luck. HighTech is THE HMI guru :-) Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 17, 2013 Report Share Posted October 17, 2013 We're going to need some example projects quickly. I couldn't get it installed on WinXP SP3 but it did install ok on my Win7 machine. Hi, it should install on Windows XP SP3, so please contact out support for further help. We are intrested of knowing why install fails because it helps us making the product and the installer better,. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted October 17, 2013 MVP 2023 Report Share Posted October 17, 2013 Thanks, HighTech. I tried to upload an image, but this forum is restricting me to a max file size of 11.04KB. I shrunk it to near unrecognizable and it was still 43KB. Perhaps you can pass along a few general tips or maybe Cara can explain why there is such a small file size restriction. 1 Quote Link to comment Share on other sites More sharing options...
HigHTech Posted October 18, 2013 Report Share Posted October 18, 2013 Thanks, HighTech. I tried to upload an image, but this forum is restricting me to a max file size of 11.04KB. I shrunk it to near unrecognizable and it was still 43KB. Perhaps you can pass along a few general tips or maybe Cara can explain why there is such a small file size restriction. Flex you can send me the image to ober.yela@imapsa.com Quote Link to comment Share on other sites More sharing options...
YINGD Posted November 4, 2013 Report Share Posted November 4, 2013 I cannot find any function within Unilogic for Alarms. I also could not find any password protection for the program. I would like to be able to password protect certain ladder functions within the program to prevent release of any proprietary features within our program. Visilogic has this feature already so if it was copied over to Unilogic, that would be wonderful! Does anyone know if I am missing either of these or if there are plans to add either feature in the near future? Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 4, 2013 Report Share Posted November 4, 2013 Hi, the alarms feature has not been developed yet, but I know of people who have developed their own Alarms using UDFBs, Structs and Data Tables (and they also created the corresponding HMI Screens). This feature is in the tasks list (so we haven't forgotten it). The password protected program is another feature that was not yet implemented, but it's in the list 1 Quote Link to comment Share on other sites More sharing options...
Kikis Posted November 5, 2013 Report Share Posted November 5, 2013 I also can't find the linearization option in the properties window of the HMI numeric entry. I am missing something or do i have to write it in ladder using the linearize command included in the math toolbox? Quote Link to comment Share on other sites More sharing options...
Ofir Posted November 6, 2013 Report Share Posted November 6, 2013 Hi, Yes you are right, you will need to use the linearization included in the math toolbox in ladder and then show the result value on the HMI. Quote Link to comment Share on other sites More sharing options...
Kikis Posted November 6, 2013 Report Share Posted November 6, 2013 Ofir, thanks for your prompt reply. I think that the linearize option should be added to the properties window of the "Numeric box" command (As it is in Visilogic and U90). It really cuts programming time and it's much more ergonomic. Also it would be great if you add the formula command in the the math toolbox (As it is in Visilogic). Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 6, 2013 Report Share Posted November 6, 2013 Hi, the formula feature is one of the things that are currently in development. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted November 6, 2013 Report Share Posted November 6, 2013 Guys, there is lots of stuff on the way--this is a new platform. That said--please do ask. Requests from our users has an impact on the priority we assign many tasks. Just be aware that some features look as though they can be accomplished with little effort, while others look complicated...but are not. Quote Link to comment Share on other sites More sharing options...
sgull Posted November 6, 2013 Report Share Posted November 6, 2013 Hi, Yes you are right, you will need to use the linearization included in the math toolbox in ladder and then show the result value on the HMI. Hi Ofir Can you not do the linerization in the hardware configuration. When you add an analog module can you give real values for the max and min in the hardware setup. Regards Denis Quote Link to comment Share on other sites More sharing options...
Ofir Posted November 18, 2013 Report Share Posted November 18, 2013 Hi Denis, In hardware configuration --> properties of the analog channel, you can already set the min/max values of the analog channel based on the scaling limits. Quote Link to comment Share on other sites More sharing options...
