Jerin Posted September 22, 2013 Report Share Posted September 22, 2013 Hello all, I have installed Remote operator and Data export in WINDOWS 8 platform for my customer. And While installing remote operator a window POP-UP and says " couldn't create common files folder" but after restarting the system remote operator working fine. But DATA EXPORT installation completed smoothly. But it always gives communication driver error by showing default 4 error checking methods. In the same system and same set-up remote operator communicated with PLC @ the same communication settings data export doesn't communicate. Is there anything I have to consider before installling.? Give me your suggestions. thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 22, 2013 MVP 2014 Report Share Posted September 22, 2013 With Visilogic in Windows 8 it is often necessary to set it for "Run as Administrator". I haven't tried DataXport but your problem sounds like it could be the same issue. Quote Link to comment Share on other sites More sharing options...
Jerin Posted September 23, 2013 Author Report Share Posted September 23, 2013 Thanks for the response Mr.Simon, But I always right click and select run as administrator only. But still I am facing te problem. Quote Link to comment Share on other sites More sharing options...
Jerin Posted September 23, 2013 Author Report Share Posted September 23, 2013 Could anyone post a list of instructions to install unitronics software in windows 8 OS.? Because most of them struggle while installing. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 26, 2013 MVP 2014 Report Share Posted September 26, 2013 Going back one step, also follow the same procedure of disabling the UAC as was necessary for Windows Vista and 7 (there is a sticky post in the this forum on that procedure). As far as I am aware, the UAC issue and the "Run as Adminstrator" issue are the only two points to note when installing under Windows 8. Are you running 32-bit or 64-bit? If things haven't gone well, I would suggest uninstalling all Visilogic software deleting the folders as detailed in this post: checking the UAC is disabled. Reboot if prompted. reinstalling the Unitronics software. I hope that helps. Quote Link to comment Share on other sites More sharing options...
