FireNeck Posted October 1, 2013 Report Share Posted October 1, 2013 Hi at all, just a quick question: As I have to upgrade to VisiLogic 9.5.0 due to access our newest software, I am missing the 9.3.1 swapper version. It's just not listed at the website. Could Unitronics load it up, so that I can securely acces my "older" versions installed at other sites with 9.3.1?? Thanks FireNeck Quote Link to comment Share on other sites More sharing options...
Michael_P Posted October 1, 2013 Report Share Posted October 1, 2013 Hi FireNeck, You can always use the previous Versions section to access that version, Just register it with the swapper before use. http://www.unitronics.com/support/previous-versions http://www.unitronics.com/Downloads/Support/Visilogic/VisiLogic%20Previous%20Versions/VisiLogicSetup_931.exe Mike Quote Link to comment Share on other sites More sharing options...
FireNeck Posted October 1, 2013 Author Report Share Posted October 1, 2013 Hi Mike, thanks for your quick response. Seems that I should stop guessing and start reading help file more intensely.... My fault, answer received, topic closed. Thanks again FireNeck Quote Link to comment Share on other sites More sharing options...
Sremac Posted August 26, 2014 Report Share Posted August 26, 2014 Can somebody explain how to register previous version with the swapper, please? BTW, when can we expect V9.5.0 Swapper? Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 26, 2014 Report Share Posted August 26, 2014 Can somebody explain how to register previous version with the swapper, please? BTW, when can we expect V9.5.0 Swapper? Hi Sremac, For working with the Visilogic version swapper you should have several Visilogic installations in several folders. All you need to do is run the swapper utility, press the folder that contains the specific Visilogic version you wish to work with and press "Register". The swapper will create a shortcut icon for running that version. Regarding V9.5 - you can always install the normal version of Visilogic 9.5.0 (don't forget to rename the folder so your current version will not be overwritten), and then use the swapper to register the current version again. Quote Link to comment Share on other sites More sharing options...
Sremac Posted August 26, 2014 Report Share Posted August 26, 2014 Dear Eyal, thank you very much for that, a am going to try it ASAP. I always wait for Swapper version of my current VisiLogic before I switch to newest version... Quote Link to comment Share on other sites More sharing options...
