External Moderators tmoulder Posted October 4, 2013 External Moderators Report Share Posted October 4, 2013 Hi all! I'm trying to update USP-070-B10. Actual OS files are: - bin files: 0.0.90, Jul-10-2013 - File System: 0.0.8, Jan-23-2013 - Kernel: 12.12.27, Dec-27-2012 I did not find where to download OS files, can you please advice me? Thanks! Quote Link to comment Share on other sites More sharing options...
EduMarg Posted March 3, 2014 Report Share Posted March 3, 2014 To update your USP-070-B10 please do as follow: 1-Insert a disk on key (formatted on FAT32) on your USB port of your PC. 2-On UniStream (latest version is 1.5.3) open a project. 3-Go to the PLC ribbon and click on the lower part of the download icon. You will get an expanded menu. 4-Select download O/S and then upgrade bin files to 1.5 5-A new window will pop up that will ask you where to save the files. As you already inserted the USB disk on key 6-it will ask you to save it there. 7-Wait until the files are copy to the disk on key. 8-Insert the disk on key on the USB port of the PLC and go to UniApps by pressing for 5 seconds the upper right corner of the screen on the PLC. 9-Go to upgrades/ Panel upgrade. 10-Select update file System 11-Wait until the PLC upgrades and reset itself. 12-Download a blank project. That’s it. If you have any other question you can contact Unitronics Support at support@unitronics.com 1 Quote Link to comment Share on other sites More sharing options...
