alexmoskos Posted October 8, 2013 Report Share Posted October 8, 2013 Hi, I am looking at the C# example provided by Unitronics for reading and writing values to a PLC via Ethernet. I am able to connect and do a number of things but I can't seem to write a value greater than 127 to the PLC. I can write values less than 127, and I am able to read a number greater than 127 but having trouble when I try to write a value greater than 127. My assumption is that it has something to do with sending a "byte" versus "short" but am still new to Visual Studio and C#. Here is the code, if the line in BIG BOLD LETTERS below is changed to anything below 127, it works but 128 or above errors out and says "Could not communicate with the PLC". Can anyone help?: private void Read_Click(object sender, EventArgs e) { ReadWriteRequest[] rw = new ReadWriteRequest[1]; rw[0] = new ReadOperands() { OperandType = OperandTypes.MI, NumberOfOperands = 3, StartAddress = 0 }; try { plc.ReadWrite(ref rw); object[] values = (object[])(rw[0].ResponseValues); for (int i=0; i<values.Length; i++) { if (values != null) { TextBox txtbox = this.groupBox1.Controls["txtMI" + i.ToString()] as TextBox; txtbox.Text = ((short)values).ToString(); } } } catch { System.Windows.Forms.MessageBox.Show("Could not communicate with the PLC"); } } private void Write_Click(object sender, EventArgs e) { object[] values = new object[3]; try { values[0] = (object)Convert.ToInt16(txtMI0.Text); values[1] = (object)Convert.ToInt16(txtMI1.Text); values[2] = (object)Convert.ToInt16(txtMI2.Text); } catch { System.Windows.Forms.MessageBox.Show("One of more of the values are not valid"); return; } ReadWriteRequest[] rw = new ReadWriteRequest[1]; rw[0] = new WriteOperands() { OperandType = OperandTypes.MI, NumberOfOperands = 3, StartAddress = 0, Values = values }; try { plc.ReadWrite(ref rw); } catch { System.Windows.Forms.MessageBox.Show("Could not communicate with the PLC"); } } Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 9, 2013 Report Share Posted October 9, 2013 Hi, we have done a lof of tests to the code and it worked in the past as it works right now, I have tried your scenario and I can write any value that I want. You did not supply the PLC Model, its OS, Boot and BinLib versions. You did not supply the Communication Driver version. (so I can't 100% simulate the case your are describing, although I can hardly believe that you are using a version that doesn't work properly). Since I don't know what project the PLC is loaded with, then I can't also tell if something is using the value of the MI (for communication for example), which might cause the problem Furthermore, the messagebox says "Could not communicate with the PLC", but what is the actual exception? (Have you tried to see what the message says?) Does the messagebox appears immediatly after cliking the button, or does it take like 9 seconds? Assuming it is a V130/V350/V570/V1210/V1040... have you tried looking at the Serial Port monitor inside the PLC (or the ethernet monitor) to see what there is in the Tx and Rx (in order to know if the PLC got the request from the PC and if it has replied)? Quote Link to comment Share on other sites More sharing options...
