danries Posted October 16, 2013 Report Share Posted October 16, 2013 We are having problems running Visilogic on one of our desktops. It has Windows 7 Professional on it. We have already tried un-installing it, disabling UAC, and then re-installing. Sometimes when trying to run it, we get "The application is already running" or "Runtime Error" then it shuts down. A few times it did open, but when trying to go to another program, it crashed and would not re-open. The PC has Avast virus software. Our network has recently been changed so that we log into a domain. Anyone have any suggestions? Thanks, Dan Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 17, 2013 MVP 2023 Report Share Posted October 17, 2013 Make sure you have "Run as Administrator" checked under the Advanced properties of the shortcut. It doesn't matter if your user level is already administrator - you have to double-bang it. Joe T. Quote Link to comment Share on other sites More sharing options...
danries Posted October 18, 2013 Author Report Share Posted October 18, 2013 thanks, Joe, will try that Quote Link to comment Share on other sites More sharing options...
tadesss Posted April 2, 2015 Report Share Posted April 2, 2015 I have same problem Quote Link to comment Share on other sites More sharing options...
carlosblitz Posted November 18, 2019 Report Share Posted November 18, 2019 buenas noches acabo de instalar el software de visilogic 9.8.65 y me aparece un error ESTA APLICACIÓN YA ESTÁ EJECUTANDO y deja abrir. espero que puedan ayudar soy en este software. gracias Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 18, 2019 Report Share Posted November 18, 2019 Hola, En algún momento VisiLogic se bloquea, pero su proceso no se cierra correctamente. Abra el Administrador de tareas, cambie a la pestaña Procesos y elimine el proceso VisiLogic.exe * 32. Si tiene algún proyecto abierto antes del crach de VisiLogic, comprométase a restaurar el proyecto. * VisiLogic guarda una copia del proyecto abierto para restaurarlo en caso de craqueo de VisiLogic. * Siempre edite el proyecto en el disco local, no en el disco en clave, no en el disco de red. Quote Link to comment Share on other sites More sharing options...
