rich Posted October 18, 2013 Report Share Posted October 18, 2013 The plant i am working on has a V570 unit installed, the company that installed the unit no longer exists. They did not burn any download, is there any way the view/change the programme. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 22, 2013 Report Share Posted October 22, 2013 To upload a project from PLC, it is neccessary to use the feature "Burn Upload Project" when downloading the project in Visilogic. This feature will burn the application (VLP file) to the flash memory of the PLC. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 25, 2013 MVP 2023 Report Share Posted October 25, 2013 No, you unfortunately can't get it. Is there any way to chase down anyone who worked at the defunct company? Joe T. Quote Link to comment Share on other sites More sharing options...
rich Posted June 9, 2015 Author Report Share Posted June 9, 2015 I working on a system controlling 10 small VSDs powering water pumps in a water feature. I am using a V350 with 10 Analog outputs to control the VSDs. Could any one recommend how I could achieve varying outputs so as to achieve several pump sequences. Quote Link to comment Share on other sites More sharing options...
Alexander Posted June 10, 2015 Report Share Posted June 10, 2015 rich, I would recommend starting a new post as this one is from several years ago and is dealing with different questions. Quote Link to comment Share on other sites More sharing options...
