mckruger Posted October 24, 2013 Report Share Posted October 24, 2013 Hi I have used linearization to calibrate high pressure reading for a pump X1: 257 (low sensor value)Y1: 4 (idle pressure)X2: 508 (high sensor value)Y2: 30 (full pressure value) X (Sensor Value): 0 (currently as not in operation)Y(Actual): -23 (value when not in operation) My question is how do i show a value of 0 or maybe a - instead of a negative value when the pump is not in operation like now. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 25, 2013 MVP 2023 Report Share Posted October 25, 2013 If you have a bit that tells you the pump is not in operation you can use it to trigger Store block to put a 0 in the MI assigned to your Y value. Put this in the network after the linear block. Joe T. Quote Link to comment Share on other sites More sharing options...
