MVP 2023 Joe Tauser Posted October 25, 2013 MVP 2023 Report Share Posted October 25, 2013 OK, so we got our Unistream and plugged in with the USB cable to upload the driver software using UniLogic as described in the Help. The PLC went into a continual reboot sequence instead of uploading the driver. Uninstalling and re-installing UniLogic did nothing. We went to the IP config app on the Unistream and manually configured the IP and were able to connect to the PLC and download a program. Thoughts? Joe T. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted October 28, 2013 Report Share Posted October 28, 2013 Joe--not clear on what happened here. Did the driver install? Did Network discovery take place? At what point did the PLC go into reboot--after a download attempt? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 28, 2013 Author MVP 2023 Report Share Posted October 28, 2013 The driver did not install or start to download. It appears to go into reboot mode immediately after Network Discovery via USB. I'll try to take a movie of it and post a link to it. Joe T. Quote Link to comment Share on other sites More sharing options...
