External Moderators tmoulder Posted October 30, 2013 External Moderators Report Share Posted October 30, 2013 Hi all! We have string data types available now, and a whole category of ladder stuff for searching and manipulating them,never the less, I cannot find any way to display a string on the HMI (analog to the ASCII String variable in VisiLogic). Where is this hide? Is there a way to invoke a variable within a fixed (or other) text object? Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted October 30, 2013 Author External Moderators Report Share Posted October 30, 2013 Ah, there it is. Thanks to Ryan for letting me know - it's the "Text Box", choose "Tag:Link" for your string variable. Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 30, 2013 Report Share Posted October 30, 2013 And you can make the textbox Read-Only and transparent, and you get an ASCII Screen variable. 1 Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted October 30, 2013 Author External Moderators Report Share Posted October 30, 2013 Thanks! Also, is it possible to: 1. Change the background and font color of the text box from the program? I used to make extensive use of the "Mark" bit in Visilogic. 2. Failing that, add the "Tag:Link" to the Binary Text box so I can change the text there, and use the linked bit to change the color? Thanks, TM Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 30, 2013 Report Share Posted October 30, 2013 About 2, you want that Text for '0' and Text for '1' would come from Tags. Am I understanding right? Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted October 30, 2013 Author External Moderators Report Share Posted October 30, 2013 Hi Saragani, That's the idea. If you check out my old "Simple Alarms" program on my blog, you get an idea of where I am going with this - fresh alarms are highlighted red, then turn white after reset. Thanks! TM Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted October 31, 2013 Report Share Posted October 31, 2013 Hey Tim :-) Very glad to see you are checking out the new system! Have you checked out the HMI training video? Quote Link to comment Share on other sites More sharing options...
HigHTech Posted December 4, 2013 Report Share Posted December 4, 2013 Disable view: I will like to have the disable view available in all the types of variables. Right now the disable color is mixing with the original color so it’s not possible to have all the colors you want. I try the transparent option (disable color set as transparent) but nothing happened. Texts: I didn’t find a way to write multi-line text. It seems that right now you can only write one line texts or variables. I really need the multi-line option. I really like the Visilogic way (clicking enter), but if you need a new command en Unilogic, so be it, but please add the multi-line option. Fixed Images: I really will like to have the set proportional command in image variables too. Custom Colors: I need to save my personal colors, because right now you need to select your own color for each type of object you put in the display. It’s taking too much time and sometimes some you can’t match precisely a custom color, please let us save our own colors or put the RGB values so we can match our own colors. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 5, 2013 Report Share Posted December 5, 2013 The disable color is just an overlay on the element, so if you put a transparent overlay on the element, then you won't see any change. In order to write multi-line text, don't click enter, but Shift+Enter (like in facebook and other websites). I'll suggest making the Enter to do Line-Feed instead of submiting. Custom Colors: In version 1.2.R5 the Color selection has been upgraded. The advanced color picker allows you to copy and paste (and also type) text to the "New Color" text box 2 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted December 5, 2013 Report Share Posted December 5, 2013 Hi Ober :-) Did Saragani's explanation of Disable color clear up the issue for you? >Fixed Images: I really will like to have the set proportional command in image variables too.< I will put in a feature request for this. Keep the comments coming, people :-) Quote Link to comment Share on other sites More sharing options...
HigHTech Posted December 5, 2013 Report Share Posted December 5, 2013 The disable color is just an overlay on the element, so if you put a transparent overlay on the element, then you won't see any change. In order to write multi-line text, don't click enter, but Shift+Enter (like in facebook and other websites). I'll suggest making the Enter to do Line-Feed instead of submiting. Custom Colors: In version 1.2.R5 the Color selection has been upgraded. The advanced color picker allows you to copy and paste (and also type) text to the "New Color" text Disable color: can you change the overlay thing? I was working on a Demo, I want BLUE color in normal mode and RED color in disabe mode. With the overlay structure I can´t have that combination of colors. I am getting blue and purple! Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted December 8, 2013 Report Share Posted December 8, 2013 Ober, I put in a request for the issue to be looked into. I don't have a time estimate... 1 Quote Link to comment Share on other sites More sharing options...
