Sign in to follow this
Joe Tauser
Unistream boot time, program editting
By my watch, the UniStream takes 50 seconds to boot.
Simple program changes require a restart after download every time.
Are both of these properties permanent in the UniStream?
"Soft Reset" is a feature that is currently being implemented and will be available on the next UniLogic+UniStream release.
In this release, changes to the HMI, and Ladder will not require reset.
Changes to Tags can sometimes requires reset under the following rules:
* If tags were added - No reset requires
* If tags were deleted - Reset is requied
* If tags got their type changed (Bit, int etc), or an Array became to a none-array or vice versa - Reset is required
* If arrays or strings got their size increased - No reset is required
* if arrays or string got their size reduced - Reset is required.
* If a tag got it's address changed (due to defrag, or due to size increased, so it does not longer fits to where it was) - Reset
All other features will require reset.
In the future we would probably support more features with "Soft Reset"
About the boot time, I have no answer.
