Sign in to follow this
pabalso
DataTables DLL Source Code
I need to build an application running only in x64 because it uses other 64bit libraries
I have recompiled the .NET driver to work in x64 but the DataTables Source Code is not available for download and recompile it. Where can i get it?
Regards
Share this post
Link to post
I've re-uploaded the file:
The Data Tables DLL and the Communication driver are from 2013, so depending on your PLC Model, it might not recognize it. I'm currently too busy to re-compile the current version, so tell me if that one works for you.
Share this post
Link to post
