chrobakpeter Posted November 18, 2013 Report Share Posted November 18, 2013 HI, I have trouble with remote operator PLC: V1210 OS:3.7 (00) REmote operator: 1.0.36.0. If I navigate to the alarm screen on. on the remote operator i See the "old" small alarm schreen. If i navigate to "Alarms in group" screen I get error message in Remote operator. (Source array was not long enough. Check schIndex and length, and the array's lows bounds) Pls. check and help me! Thanks, Peter Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 18, 2013 Report Share Posted November 18, 2013 Hi, remote operator has not yet implemented the new alarms display, but it scheduled for the next release of Remote Operator. Can you verify that Remote Access (the old Remoting application that comes with Visilogic) shows the "Alarms in Group" without any error? (like subscript out of range) Quote Link to comment Share on other sites More sharing options...
chrobakpeter Posted November 20, 2013 Author Report Share Posted November 20, 2013 Hi, Visilogic (9.5.0)-rmote access: old alarm display. Navigating to "alarms in group" :Run Time Error 9: subsript out of range Peter Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted November 20, 2013 Report Share Posted November 20, 2013 When will be released new version of remote operator with correct alarm display support for v1040/1210 series ? Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 20, 2013 Report Share Posted November 20, 2013 I cannot give you an exact date, but I know that there is a version of Visilogic/Remote Access that is able to show the new alarms display (it is probably a Beta which is a newer version than 9.5) Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted November 20, 2013 Report Share Posted November 20, 2013 Where I can find beta version ? Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 25, 2013 Report Share Posted November 25, 2013 Hi, the beta version is not yet available, but however, the Remote Operator version is currently being coded and you should expect it soon Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 27, 2013 Report Share Posted November 27, 2013 Hi, please try Remote Operator 1.0.38: http://www.unitronics.com/Downloads/Support/Software%20Utilities/Remote%20Operator%20Version%201.0.38.zip You should now see the new alarms display on both V1040 and V1210. chrobakpeter, please see if the problem of the "Source array was not long enough" is reproduciable. Currently I don't know if the fault is because the old Remote Operator was not getting the right information from the PLC because of the new Alarms, or is it a bug in Remote Operator/Remote Access, or it's a problem with the Alarms in the PLC not supplying the correct information for Remote Operator/Access. I have never encountered the problem you have described for the Alarms, so I hope this issue will be resolved by the new Alarms display. If this issue continue to happen with the new Remote Operator, then please send us the project (I'm not sure that we will be able to reproduce it here, since the Alarms that will will get are different in types and ammount from the Alarms in your PLC). Thank you for your feedback. 1 Quote Link to comment Share on other sites More sharing options...
chrobakpeter Posted December 10, 2013 Author Report Share Posted December 10, 2013 Now it works fine! Remote operator 1.0.38. +updated os to PLC (got from the support). OS:V3.7 (32) Thanks, Peter 1 Quote Link to comment Share on other sites More sharing options...
