Alarms from sd card
viper_lasser
  • 1 year later...
Hi, first sorry about the English (I am Brazilian). I am using the Unitronics.ComDriver library (plc [0] .SD.ReadFile) to read data from tables in a SD card inserted into a Unitronics PLC, however this function returns me a byte array and I can not identify from byte which begins the first element of the table.
I have also used the Unitronics.SD.Files library to read the udt files saved with the functions described above, but just need to save the udt files on my hard disk and then read in the form of .NET tables.
Can I read directly from the PLC tables for a .NET table?
