Gary Plunkett Posted November 20, 2013 Report Share Posted November 20, 2013 Hi, Is there any way to load a program into a UniStream controller via a microSD card or USB memory stick? The new software looks great by the way. Is there any thought towards developing the ability for online programming edits? Quote Link to comment Share on other sites More sharing options...
NoamM Posted January 3, 2017 Report Share Posted January 3, 2017 Hi, loading a program via a USB memory stick can be done in the next manner: #1 - From UniLogic download the application to a USB stick #2 - Connect it to your UniStream and go to UniApps -> System -> Upgrade -> User App Upgrade and press 'Import Application': Regarding your other question,online program edits (content of a data tag for example) can be done by connecting UniLogic to your UniStream (USB / Ethernet) and pressing 'online' (when your application is identical in both UniStream & UniLogic) like so: 1 Quote Link to comment Share on other sites More sharing options...
dan Posted January 3, 2017 Report Share Posted January 3, 2017 Hi Gary, Noam, You can load a Program via a USB Stick by navigating to Download > Export project to USB storage, as Noam suggested. Using UniLogic, a user can view live data in the controller using the Online mode. However, online edits to the program are not available in this mode. The edits must be made offline and downloaded. Dan. Quote Link to comment Share on other sites More sharing options...
CLanford Posted June 18, 2020 Report Share Posted June 18, 2020 On 1/3/2017 at 10:03 AM, dan said: Hi Gary, Noam, You can load a Program via a USB Stick by navigating to Download > Export project to USB storage, as Noam suggested. Using UniLogic, a user can view live data in the controller using the Online mode. However, online edits to the program are not available in this mode. The edits must be made offline and downloaded. Dan. Is there anything special about the USB export option? The reason I ask is I'm in the process of doing firmware updates that require the program to be re-downloaded. The problem is since Unilogic can only run 1 instance per computer, I'm running my upgraded project version on a virtual machine thus no USB inputs. I could virtualize the USB input from my host machine, but this is on a corporate computer and getting the access rights to this is untenable. Can I not just save the ulpr file manually onto the stick and dump it that way? Or is that not possible? Quote Link to comment Share on other sites More sharing options...
CLanford Posted June 19, 2020 Report Share Posted June 19, 2020 21 hours ago, CLanford said: Is there anything special about the USB export option? The reason I ask is I'm in the process of doing firmware updates that require the program to be re-downloaded. The problem is since Unilogic can only run 1 instance per computer, I'm running my upgraded project version on a virtual machine thus no USB inputs. I could virtualize the USB input from my host machine, but this is on a corporate computer and getting the access rights to this is untenable. Can I not just save the ulpr file manually onto the stick and dump it that way? Or is that not possible? Quoting myself here, I have learned that yes there are indeed special characteristics of the USB export function. This is solely based on my attempts to export out of an existing controller onto a USB and observing the file structure. It is vastly different than just a ulpr file. Everything seems to be packaged quite separately in the USB export dump, and the configurations seem to be split into many files and folders of varying types. It doesn't even appear that I can back into these files by exporting individual components out of unilogic either because the file structure is so different. So it appears I'll be forced to install the software I need onto a different laptop so I can create this file. Quote Link to comment Share on other sites More sharing options...
