Communication between UniOPC and Mitsubishi PLC
I have problems with communication between UniOPC and Mitsubishi PLC. Using MXOPC and Linkmaster between them.
Theni relized that i need som sort of software to generate the Tags for UniOPC.
It a Mitsubishi Q-PLC and a Vision 130.
Can i use Linkmaster, then how? Or is it som sort of different software then wil be needed?
Hoping for som sort of solution!
Good morning from the north!
