Malcolm Posted November 27, 2010 Report Share Posted November 27, 2010 Hello, Is there any development to integrate profibus and profinet into Unitronics? Regards. Quote Link to comment Share on other sites More sharing options...
Emil Posted November 28, 2010 Report Share Posted November 28, 2010 We are working on Profibus Slave optional card for V130/350, but the issue is not scheduled yet. Quote Link to comment Share on other sites More sharing options...
Damian Posted November 30, 2010 Report Share Posted November 30, 2010 We are working on Profibus Slave optional card for V130/350, but the issue is not scheduled yet. Why would they make it exclusive to the V230/250? There are Siemens HMI's in the area that I could replace with a V570 if they had profibus. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted December 1, 2010 MVP 2014 Report Share Posted December 1, 2010 Good point Damian, I have seen the same opportunity with the V570, that is not really valid for the smaller units. Also, if there was a Profibus card for the V570, I presume it would also suit the V1040... Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted December 2, 2010 Report Share Posted December 2, 2010 Thanks for your observations, guys. I forwarded them to the relevant people However--note that we are working, currently, on a slave solution.... Quote Link to comment Share on other sites More sharing options...
Blitz Posted June 18, 2011 Report Share Posted June 18, 2011 I would just like to know if there are any updates with the release of Profibus cards for Vision controllers. Will it be available any time soon? Thanks. Quote Link to comment Share on other sites More sharing options...
Interroga Posted May 18, 2018 Report Share Posted May 18, 2018 any good new about profinet communications in unilogic? I need command one inverter in this protocol! Heeellllpppp! Regards. Mauro Quote Link to comment Share on other sites More sharing options...
sgull Posted May 18, 2018 Report Share Posted May 18, 2018 There is a Profibus card available for the V130,350,430 and for the V700 You can also use a modbus to profibus converter on other models Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 18, 2018 MVP 2023 Report Share Posted May 18, 2018 Profinet is Siemens' Ethernet protocol. Profibus is a serial protocol. You'll need a converter to change it to Modbus IP - Google "profinet to modbus tcp". Joe T. Quote Link to comment Share on other sites More sharing options...
oreillej2899 Posted September 6, 2018 Report Share Posted September 6, 2018 We used a MODBUS (SLAVE) Client to Profibus Server(Master) Gateway successfully using Unistream/Unilogic. ANYBUS "AB7808" for MODBUS RTU Slave to PROFIBUS MASTER gateway Quote Link to comment Share on other sites More sharing options...
