michael10 Posted January 3, 2014 Report Share Posted January 3, 2014 Hi everybody thank you for your support. When trying to write to SD card with the csv file to two Different locations it seems that for some reason its not working, although i made a delay between the writing commands. when writing to one file it is working. Thank you in advance for your help Attached Files try4.vlp Quote Link to comment Share on other sites More sharing options...
Ryan Posted January 3, 2014 Report Share Posted January 3, 2014 Hi Michael, When debugging I find it always helps to test everything step by step before connecting them all. If you put each CSV write on separate MBs and trigger them manually do they both write successfully? If so you may need to change the delay or conditions between the two. If not, then it could be a problem with the file name, check the status message in each write FB for a better clue as to what went wrong. Regards, Ryan Quote Link to comment Share on other sites More sharing options...
